Farmall Cub sickle pitman pin/flywheel
Posted by Ed Marshall on July 16, 2000 at 20:32:30 from (208.145.244.221):
The pin attached to the mower flywheel that holds the pitman is sooooo worn that I can't keep a bushing in the pitman. I want to replace the pin. But I can't determine if this pin is threaded into the flywheel, pressed into the flywheel, or what??? And, IF it is threaded, in which direction, left or right??? If you've killed this dragon before please tell me how it's done.
Post A Followup
: Re: Farmall Cub sickle pitman pin/flywheel
