Re: MV dropdown
Posted by Janicholson on February 20, 2011 at 17:32:16 from (67.72.98.45):
In Reply to: MV dropdown posted by Andy Hixson on February 20, 2011 at 17:22:47:
You are going to take it off either way, so why not remove it and clean it up at the weld area, and have a good weld shop look at it. If it is repairable such that it can be ground back to original contour it will last and be cheaper than transportation. Jim
