All Detroit diesel 2 strokes used pressurized air to blow the exhaust out of the top of the cylinder through regular exhaust valves (2or 4 of them, no intakes at all) the pressure is produces by a supercharger. stuck to the side of the engine, blowing into a plenum surrounding the middle of the cylinder wall. Each cylinder has perimeter ports in a ring. These are located just above the point of lowest travel of the piston. Fuel is injected and ignites with max pressure just after TDC. Piston moves down expanding the heated combustion gasses. Crankshaft drives the blower, pressurizing the air in the plenum. As the piston clears the ports, the exhaust valves are opened (cam operation). The compressed air purges the exhaust out of the cylinder and fills it with air. Compression happens heating the air for the next injection cycle. The crank case is closed and operates just like a 4 stroke. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
