Re: farmall super a
Posted by Andrew Z on February 21, 2011 at 10:26:15 from (64.252.115.246):
In Reply to: farmall super a posted by gidtex on February 21, 2011 at 09:47:47:
they look very simalar, and the parts number are the same, but when looking in the parts book the belt pully delete for a Super C or C shows it to be used for only a 'SC' or 'C'.
However with that being said i took the delete off a Farmall 100, almost the same as the Super A, and put is on a Super C, no problems. I would say the diffrence between the C style and A style delete may have to do with the gaurd bolt holes, not sure though. In short you should not have a issue that i can for see.
Andrew
