Re: generator belt
Posted by Dellbertt on February 21, 2011 at 15:05:30 from (209.172.21.126):
In Reply to: generator belt posted by Marlin taylor on February 21, 2011 at 12:14:45:
I have drilled 2 of them out. I would rather do that than remove the pump. Take your time. Tap the threads if you have to.
After you get it out and repaired, install a hex head bolt instead of a slotted screw. It makes life easier the next time you need to adjust the belt.
Dell
