Re: generator belt
Posted by Tom Fleming on February 21, 2011 at 15:14:20 from (67.20.243.240):
In Reply to: generator belt posted by Marlin taylor on February 21, 2011 at 12:14:45:
I am with Dell, drill it out and re-tap it. Good news is that you can do this. Bad news is, if the set screw is a hardened one (like on the crank pulley on a C-113 engine), you will need a carbide tip to drill it out. I have a complete set of Cobalt left hand drills, and they wouldn't touch the broken set screw on the crank pulley. I used a 5/16 tile drill to get it out.
However, not sure if all the set screws were hardened or not. Try a regular drill first, and go from there.
