Re: Re: Re: Re: Re: Re: cub elect. problems
Posted by The Red on July 17, 2000 at 05:26:43 from (12.75.197.75):
In Reply to: Re: Re: Re: Re: Re: cub elect. problems posted by Mike Honour on July 16, 2000 at 18:47:19:
Mike if you have an alternator, the bat terminal wire from the alternator should be connected to the ampmeter post that has the wires for the ignition coil and the wire going to the light switch assembly. There should be no wire going to the field resistor. I don't believe it is used at all in the alternator settup.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: cub elect. problems
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
