The problem is, you'll need one huge honkin' multimeter to measure the source of your "drain:" THE STARTER.
No other electrical component on your tractor draws nearly as much current as the starter while it's cranking the engine. It would take 15-20 headlight bulbs to even begin to draw on the battery as hard as the starter does.
Your starter probably isn't in the best of shape. It may have a shorted winding that's causing it to draw far more current than it would normally.
Had a similar problem with a starter in a Super C recently. The starter would crank the tractor fine, but the tractor wouldn't start. Swapped in a junkyard starter and viola!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
