Re: Farmall 100 Died and Now Wont Start
Posted by old on February 21, 2011 at 20:49:01 from (4.245.8.233):
In Reply to: Farmall 100 Died and Now Wont Start posted by RHeimiller on February 21, 2011 at 20:25:06:
Pull the coil wire out of the center of the distributor cap. Then spin the engine over. If you get spark there then check for spark at the plug wires. Spark needs to be blue white in color and jump a 1/4 inch gap. If you get no spark take the cap off the distributor and with the switch on open and close the points by hand. You should both see and hear a spark there. If no spark check the gap and also clean the points. If after cleaning the points you still do not have spark make sure there is not something shorted out inside the cap area.
