Changing to a 6 Volt starter motor will have no effect whatsoever on the ignition system. Moreover, the 6 Volt starter will not be harmed by running on 12 volts.
Always check the obvious first:
1). Is it getting fuel?
2). Is there water in the fuel?
3). Is there spark at the spark plug?
4). Is ignition switch operating? (check for short circuit)
5). Are the coil connections tight (check wire into back of terminal!)
6). Is the breaker point and spark plug gaps correct?
7). Is the ignition timing correct? Check the distributor is rotating as it should.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
