Re: Measuring electricity
Posted by Brownie 450 on February 22, 2011 at 05:39:39 from (66.43.241.198):
In Reply to: Measuring electricity posted by JTKY on February 21, 2011 at 15:13:47:
If the starter is in good shape [only 3 years], look for bad connections going to the coil/ distributor. This includes everything from the ammeter up through the distributor--even the ground side of the points. You may have to run a jumper wire up to the distributor from the battery just to prove out that it will or will not start normally.
We had the SMTA act like this, & it turned out to be the wire going to the dist. was down to 3 wires left in the stranded wire where it went up over the valve cover. No explanation why this happened, but it sure caused trouble.
