Re: Re: Re: Red Hot Light Switch
Posted by Bob M - w/ diagram on July 17, 2000 at 07:42:21 from (192.232.120.194):
In Reply to: Re: Re: Red Hot Light Switch posted by Mike Honour on July 16, 2000 at 18:28:38:
third party image
Hi again Mike. Had some unexpected downtime this morning (rain!). Used the opportunity to modify a diagram for you. Presuming your light switch looks like this from the back, this is how your wiring should look.
Two notes: 1 - Make sure nothing is connected to the field circuit terminal (suggest taping it over, or removing it entirely if you can). 2 - The DPDT switch should look like shown in the diagram from the back (connection) side. You may find when you get done it works reverse of what you expect (up for "stop and down for "run". If it does, simply rotate it 180 deg in the ammeter panel.
Hope this helps...
Bob M
Post A Followup
: Re: Re: Re: Re: Red Hot Light Switch
