Re: to drop oil pan, or not to drop oil pan . . . ?
Posted by FC Andy on February 22, 2011 at 13:01:03 from (74.126.84.52):
In Reply to: to drop oil pan, or not to drop oil pan . . . ? posted by e-manhunt on February 22, 2011 at 07:47:56:
Definetly pull the pan and clean it! That is the one of the first things I do when getting a tractor now. I lost the lower end on my C due to sludge, and I don't plan on doing that again. This was a matter of probably 30 years of sludge, I didn't know it was there, I changed the oil yearly, but none ever came out, at least until one spring morning about 5 years after I got it. (I figure yearly is good enough for a tractor that sees 10-20 hours use annually) So, I learned my lesson the hard way. Clean your oil pan. Might just save an overhaul.
This post was edited by FC Andy at 13:04:38 02/22/11.
