Re: Can a '41 distillate H pull a fully loaded haywagon i...
Posted by K-Mo on February 22, 2011 at 14:11:32 from (67.55.164.37):
In Reply to: Can a '41 distillate H pull a fully loaded haywagon in 5th? posted by Yooper Farmall on February 22, 2011 at 13:14:46:
When going up and down hills, keep in mind the weight of the load vs weight of the tractor. I assume your hay wagon probably does not have brakes. If your load is heavier than your tractor, going down hill on gravel could be a killer.
I guess one indicator with an H is if it won't pull it up hill, then you don't want the load chasing you down the hill.
