Posted by LOU from Wi. on February 22, 2011 at 16:49:13 from (174.124.110.80):
In Reply to: 706 Starter posted by Rtkman-706 on February 22, 2011 at 12:00:07:
WE take em apart. Clean up with carb spray cleaner /air dry- Grease in bearing hole Check with V>O.meter around armature for dead spots. Use a dremel tool with thin cut off wheels, then cut out excess mica between armature plates.(be careful not to over depth cut. Install new brushes. Check solenoid. Re assemble ,taping end of housing to get correct seating of end plate/nose casting.We also use di-electric grease on all the elec. connections Should be good to go. Done one heck of a lot of em over the years. Regards LOU & Victor.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
