The 12 inch disk will come out without splitting the tractor but you can't get the pressure plate out.
You should be able to get the yoke off the transmission input shaft if you use three of the pressure plate mounting bolts to draw the levers in and then remove the other three mounting bolts. After removing the two bolts that hold the release bearing carrier support, pull the clutch shaft back enough to get it out of the pilot bearing in the flywheel. You should then be able to move it to the side enough to slide the yoke off the transmission input shaft.
Today's Featured Article - A Tractor's Point of View - by John Manley. I began my life on August 3,1941. I was actually built at different times and days but I was officially an M Farmall on August 3.I was real nice and shiny. That’s me, in the old picture, third from the left. I was loaded on that train and sent to a little town in South Carolina. I didn’t get to see much of that town. I was moved off the train fast and on to the dealer’s
... [Read Article]
Latest Ad:
[More Ads]
