This i what I do on every "new' old motor I acquire.
Drop oil pan and clean it and the oil pump pick up. As long as your at it pull the valve cover and clean that up also. Buy some sheets of gasket material and make your own gaskets. RTV works great but I would rather use gaskets.
If it's really filthy I have pressure washed the motor from the top and bottom. Yes I run water down through the motor. (not into the cylinders)
I then pour in 3-5 gallons of diesel fuel in the motor and let it set for a couple days or until I get back to it. Drain the diesel and put in fresh oil and filter.
I have done this on multiple motors,this technique was passed down through my family for at least 3 generations. Grandpa used kerosene.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
