Precisely. The filter might warm up a little with heat from the block through the mount, but it is always drawing in cool air under vacuum so it never gets truly warm. When in operation, most of the oil that rests in the cup is up in the mesh/wool and any moisture in the intake air, whether it passes over or throght the oil has an opportunity, if the conditions are right, to emulsify to some extent with the oil.
At the same time, that filter is subject to the same kind of inernal condensation that can get into a crankcase, that from wide and rap[id temperature fluctuations while it is just sitting.
The difference is that your crankcase oil will get hot when you run it and if run long enough will steam off any water that has emulsified with the oil. That filter cup never gets hot enough to do the same thing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
