Re: Can a '41 distillate H pull a fully loaded haywagon i...
Posted by dhermesc on February 23, 2011 at 05:55:32 from (24.248.193.103):
In Reply to: Can a '41 distillate H pull a fully loaded haywagon in 5th? posted by Yooper Farmall on February 22, 2011 at 13:14:46:
We pulled lots of hay for miles with an H. Usually our wagons held 110 to 130 bales weighing from 50# to 80#. Start it out in fourth then grind it into fifth. Some big hills you have to downshift back to 4th. Make sure your brakes work so you can stop. Usually had a person on the wagon to let you know if someone was coming up behind you. Dad's rule was you had to be 12 to drive the tractor and 7 to ride the wagon. Once every two years or so someone would lose a load but restacking it by yourself on the side of the road cured the foolishness that caused those mistakes.
