Re: to drop oil pan, or not to drop oil pan . . . ?
Posted by Allan from PA on February 23, 2011 at 07:43:24 from (76.125.180.44):
In Reply to: to drop oil pan, or not to drop oil pan . . . ? posted by e-manhunt on February 22, 2011 at 07:47:56:
Definitely drop the pan. Not a time consuming process. As others have stated check under the valve cover also. Bought a 1945 AV and it had about an inch of silvery sludge in pan and around valves. Cleaned it all out and engine has been running good since. Never did figure out what the silvery sludge was though. Allan.
