Re: Cub belt. ARRRRGH
Posted by Mark W. on July 17, 2000 at 10:53:06 from (209.6.106.197):
In Reply to: Cub belt. ARRRRGH posted by Louise on July 16, 2000 at 08:59:31:
Louise: I'll try to keep this as short as I can. Possibilites to check are pulley alignment, belt tension, and foreign objects. If you had the wrong pulley it may have caused an alignment problem. If you buy the new one, be sure the "protrusion" faces the right way if you have an assembly drawing. If you don't have a drawing, install the pulley to optimize its alignment with the other pulley(s) with the deck in the mowing position. If it still looks cockeyed you may have a bent spindle or some other warped/broken part (not likely), or an extremely bad bearing (unlikely to be that bad). Be sure the belt is neither too tight (not likely) nor too loose (possible). As for foreign objects, here's what happened to me. It's a long shot but it may apply in your case: A small piece of stick broke off and lodged unnoticed in a groove on one of the pulleys. The next thing I knew, the belt broke (it was about 2 years old). I put on a new belt and it broke within two hours. I traced the problem to the little piece of wood, which was worn smooth and had created a small (maybe 3/16") bump in the pulley groove. Each time the pulley revolved the bump would wiggle the belt just enough that the outside of the belt (where its strength is) rubbed on a belt guide. It didn't take long for the outside of the belt to fray enough for the belt to break. I popped the wood off the pulley with a small screwdriver and have had no problems since. So, check your pulley grooves for stuff that shouldn't be there. If the pulleys you still have are O.K. it may be worth a walk in the weeds to check the one that flew off. Try to avoid finding it the hard way (with the bush hog)! Good luck - - Mark W.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
