Re: Farmall A serial number
Posted by Jim350 on February 23, 2011 at 14:12:02 from (72.228.48.9):
In Reply to: Farmall A serial number posted by Josh Cole on February 23, 2011 at 13:34:26:
The charts will not have the FAA in them.
That justs means it an A.
The number you posted is too low.
Wet the plate with some water and a rag.
That will make the numbers stand out a little bit.
See if you read the first number wrong.
