Re: Crankcase Cracked! Can It Be Repaired?
Posted by Janicholson on February 23, 2011 at 14:16:29 from (199.17.6.194):
In Reply to: Crankcase Cracked! Can It Be Repaired? posted by dunniteowl on February 23, 2011 at 13:04:26:
Jb weld and its relitives are not in the same categorie as metal. They have no tensile strength to speak of at all, and do not adhere to oily metal if they did. They are wonderful, but not for the stress applied 9as you have experienced. Now that it is cracked the real twsk will be to either replace the block, transferring all components (read major mechanics), or have the crack ved out and welded properly. The different block will cost as much as the weld, and be a better fix. It will add the mechanics work of replacement. Sorry there is no sweet fix for this issue. Jim
