Re: Crankcase Cracked! Can It Be Repaired?
Posted by gab on February 23, 2011 at 15:26:46 from (70.105.107.119):
In Reply to: Crankcase Cracked! Can It Be Repaired? posted by dunniteowl on February 23, 2011 at 13:04:26:
You screw around with jb weld and you will end up with the frt end on the ground with the oil pan on top of the radiator, get it welded.
