Re: Fan Pulley Farmall 300
Posted by pete 23 on February 23, 2011 at 16:30:46 from (173.87.146.142):
In Reply to: Fan Pulley Farmall 300 posted by Lee Jr. on February 23, 2011 at 08:47:03:
You should be able to just drive the pin in if bearings and spacer are out of there. No need to disturb the packings as they are in the other part of the pump. New seals, ya, bearings should be fine unless you damage them. Might even save the seals.
