Posted by james Ashcraft on February 23, 2011 at 19:01:33 from (70.242.119.145):
In Reply to: Hydraulic Issues posted by farmall706 on February 18, 2011 at 21:10:19:
This may be just a shot in the dark. A few years I purchased a 686 and had the same problems as you described. I don''t know how close the 707 hudraulic pump is to the 686. So I drained the fluid from the belly of the tractor and cleaned the left side where you remove the pump. I removed the outside plate that the pump is bolted to and removed the plate with the pump attached to it. I discovered at the back of the pump is tube with o rings that attaches to filter on the right side of the tractor. The o rings were shot on the tube and that would let air be sucked until the fluid gradually built up pressure. I looked on the caseIH web sight under 706 hydraulic pump and found listed on the exploded view #12 - TUBE ASSY, pump section and this appears to be close to what I have on the 686. I got the part from CASEIH and reinstalled the pump and filled the hydraulic sump with the correct amount of fluid and there was a big time difference in the sound and the way the ps and other hydraulic worked. Hope this helps. Before I started I ordered a manual from the wed sight so help me along.
James
This post was edited by james Ashcraft at 19:03:03 02/23/11.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
