Re: Separating oil and water.
Posted by Brian Schmidt on February 23, 2011 at 20:25:31 from (97.64.182.171):
In Reply to: Separating oil and water. posted by Fullers Farmalls on February 23, 2011 at 19:57:25:
Best to toss it and put in new.
If you are set on saving it though, you could try heating it in a turkey cooker 3 or 4 gallons at a time to boil the water out. Just don"t burn it.
