Re: Carb bowl gasket
Posted by rustyfarmall on February 24, 2011 at 04:41:37 from (209.152.78.140):
In Reply to: Carb bowl gasket posted by Lee Jr. on February 23, 2011 at 18:40:39:
Use NEW screws and lock washers, and run a threading tap through the bolt holes first. A quality carb rebuild is worth new hardware.
