Re: Hydraulic Issues
Posted by mkirsch on February 24, 2011 at 05:06:52 from (64.80.110.74):
In Reply to: Hydraulic Issues posted by farmall706 on February 18, 2011 at 21:10:19:
686 and 706 are completely different.
The issue with the 706 and other large frame tractors is an O-ring that seals between two separate housings for the oil pickup. You have to split the two housings apart to replace the O-ring, which means most of the tractor has to come apart.
Would overfilling as a standard course of action be advisable as a preventative maintenance measure? Keeping the O-ring submerged in oil would slow its decay.
