Posted by Brownie 450 on February 24, 2011 at 05:56:16 from (66.43.241.198):
In Reply to: Carb bowl gasket posted by Zachary Hoyt on February 23, 2011 at 18:40:39:
Is the bowl flat on the mating surface? If the corners are "pulled" a little, put a sheet of 100 grit emery cloth on a 2x6 & stroke the bowl across the emery cloth until flat. As Russ said--drill out the unthreaded holes.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
