Re: Separating oil and water.
Posted by mkirsch on February 24, 2011 at 08:05:28 from (64.80.110.74):
In Reply to: Separating oil and water. posted by Fullers Farmalls on February 23, 2011 at 19:57:25:
You sure you don't mean rear end lube?
An H only holds about 6 quarts of hydraulic fluid, but it holds around 5 gallons of heavy gear lube in the rear end.
A 5 gallon bucket of gear lube is around $60 at Tractor Supply, less if you catch it on sale.
You can't even begin to touch any real water separation equipment for $60, and even if you could, you'd still have old oil that needs to be replaced.
