Re: 460 carburator sticks
Posted by pete 23 on February 24, 2011 at 09:57:02 from (173.87.146.142):
In Reply to: 460 carburator sticks posted by Michael Schwartz on February 23, 2011 at 12:51:19:
Fabricating a stove around the muffler and running a tube to pull warmed drier air into the air cleaner inlet will help a lot. If you are using a snow blower you have alot of moisture getting sucked into carb causing the excess icing. I have seen this done on H models with real good results. Lot of carbureted auto engines have a setup like that.
