Jimmy Z. from erie,pa. said: (quoted from post at 13:40:27 02/24/11) sflem849- Speed gear pic- First: on the left side of your picture were the corner oil splash webs are by hammer,mine looks "ground"(both sides) as if done in factory? The lip is almost gone. Don't see cause- just unusual. Second: My mid gear( for belt pulley?)has beveled teeth like yours.Is that normal, or wear? The double gear facing mid gear is slightly beveled also( I think this is from belt pulley gear engagement). Third: The second gear in from the left has a shoulder in teeth like yours and the largest diameter looks "sharpened" like yours. Is that normal? Fourth: The bottom first gear on left is the one missing at least two consecutive teeth. Looks like a split job to me. Any idea on cost of bottom gear? I have not identified it yet for parts search....
By bottom gear, I'm guessing you're refering to the Constant Mesh Gear. I drew an arrow to it in the picture at the bottom. I broke this gear on my H two years ago. It is a discontinued part, and somewhat hard to find, at least it was for me. I looked online for about a month, and one happened to pop up on Ebay new and in packaging. I believe it was 175.00 or so. Mine was due to the mainshaft pilot bearing going bad, allowing play in the shaft which caused the gear to break off a few teeth while under a load. You do not have to split the tractor to replace it. You will have to remove your hydraulic belly pump, and work from underneath. It's not a fun job.
And this is where mine broke.
This post was edited by Faster346 at 13:21:23 02/24/11 2 times.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
