Re: Separating oil and water.
Posted by sflem849 on February 24, 2011 at 13:50:43 from (69.197.84.192):
In Reply to: Separating oil and water. posted by sflem849 on February 23, 2011 at 19:57:25:
Makes sense, but there is so much emulsified oil that it is nearly impossible to get it out without a filter.
I have heard of cooking hytran off in a turkey fryer type setup. I don't think it would ever separate out to take the chunk of ice out. I would cook it in a fryer, but ultimately it will need new oil. It will take a couple changes with cycling of the hydraulics to make it clean(er).
Can you run them and get them hot to cook out the water like in an engine?
