Re: Super A pilot bushing
Posted by Janicholson on February 24, 2011 at 14:24:18 from (199.17.6.194):
In Reply to: Super A pilot bushing posted by CNKS on February 24, 2011 at 14:08:33:
Easiest method is to find a piece of aluminum that can be sanded to a tight fit in the bearing. Pack grease in the hole of the bearing and use the rod as a hydaulic piston to push the bushing out of the crank. Pounding it in smashes the grease, which pushes against the rear edge of the bushing forcing it out.
A slide hammer is also used for this. with a wedge adjusted spreader tool.
A third method is to use a tap that fits the hole in the bushing ( guessing 1/2-13) threading the bushing. Keep threading until the bushing is pushed out of the hole by the tap hitting the bottom of the hole if the tap seems to want to jamb or break before it moves, put a bolt in the new threads and pull on that! . Good luck Jim
