Re: i know this isn't normal/ does yours do this
Posted by mkirsch on February 25, 2011 at 05:12:36 from (64.80.110.74):
In Reply to: i know this isn't normal/ does yours do this posted by bob-b on February 24, 2011 at 20:20:40:
The bearings are made of hardened steel, and are designed to carry many times the weight of the tractor. They certainly do NOT "go oval" just sitting around.
The only way the bearing would deform is if the races were worn paper thin. You would have experienced OBVIOUS problems long before that point, though.
Rear tractor tires are all a little bit "square." They have flat spots. They are oval shaped. All of them. Especially cold.
