Re: Checking an alternator
Posted by teddy52food on February 25, 2011 at 07:57:11 from (68.169.216.43):
In Reply to: Re: Checking an alternator posted by IBorange in TX on February 24, 2011 at 19:32:45:
That only tells you that the field rotor is energized. If the diodes are bad or stator windings are open or shorted it still won't charge.
