Re: I'm Leaking Diesel Fuel, Again!
Posted by soybeanjoe on February 25, 2011 at 10:43:40 from (66.213.171.108):
In Reply to: I'm Leaking Diesel Fuel, Again! posted by FC Andy on February 25, 2011 at 09:53:01:
If you want to cure the leaking go to your CIH dealer & buy the "new style" ings that have the plastic (nylon) inserts & metal o-ring. They are a little salty, about $4.95 ea IIRC compared to about 92¢ ea for the copper. IIRC originally the Roosamaster pumps used the copper washers but I never could keep them from eventually leaking. Seems you either over tighten them & they split or you don't get them tight enough & they leak. They later came out with steel washers but I never had much luck with them either
WE had the pump rebuilt on our old 806 last year & the pump shop sent it back with a set of copper & a set of steel rings. Case IH service manager recomended the plastic / o-ring style. So far they haven't leaked. They are a PITA to install as the insert will pop out for almost no reason. I solved that problem by putting a small dallop of super glue 180º apart in the inside grove of the metal ring.
