Re: Farmall H carb.
Posted by old on February 25, 2011 at 13:52:26 from (4.245.9.15):
In Reply to: Farmall H carb. posted by Jamesmn on February 25, 2011 at 13:24:44:
Do you have the float set correctly?? Is the needle seat good and tight?? Did you install a new float needle and is it a rubber tipped one?? If rubber tipped they need to have a set put in them and to do that you drop the needle in the seat and tap on it a couple times. Are you sure that the float is good and doesn't have a small hole in it. They can look good but still be bad. Shake the float if it rattles it is bad
