It almost sounds like the TA clutch is dragging/out of adjustment and a worn shift lever. If the TA clutch is dragging it will put a load to the low side of the gear selected making it difficult to get out of gear. Adjust the TA per IH instructions in the manual, can't remeber the specs, Jim will probably weigh in with the specs. The Shift lever being excessively wore will not fully actuate the shift rails engaging two gears and stalling the tractor. If you can not find a good shifter it is possible to weld up the end and file it to new specs.The TA clutch could be the source of the smell if not correctly adjusted. Hope this helps.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
