Re: Farmall H carb.
Posted by BobsFunkyFord on February 25, 2011 at 18:14:02 from (24.32.21.45):
In Reply to: Farmall H carb. posted by Jamesmn on February 25, 2011 at 13:24:44:
Is it leaking, or running, out of the air intake port? Or, is it dripping from the "load screw"? I just rebuilt a Super M IHC carb which had a bad needle valve. Gas was running out of the air intake (hose removed). Another post a few days ago, pintobill, had gas dripping from the load screw following a rebuild. His problem is likely the lead packing which should be in the kit, however not in his. I bought my kit on eBay from bakt4kids. The mistake I made after the rebuild was that I had the idle adjustment screw on the governor set way too high. So within seconds of the engine starting, it broke the fan blades and was schrapnel taking out the radiator and shroud. Hope this helps, Bob in Texas
