Re: Farmall 450 transmissions problems
Posted by rustred on February 25, 2011 at 18:31:31 from (74.200.18.155):
In Reply to: Farmall 450 transmissions problems posted by Tony_Idaho on February 25, 2011 at 17:57:23:
your stuck in two gears . unbolt shifter and pull it out then get a cat bar and line up the shifting rails again. rebolt shifter back in and good to go. shifter on bottom gets worn a bit and then when shifting in a hurry this is what happens. need to build up shifter.
