If it is hard to get out of gear, the TA is out of adjustment. As to the gearshift, the rails are now out of alignment. You can pull the belt pulley, or the cover if no pulley and align them. But the lower part of the shifter may need to be fixed also, if worn. Once the rails are aligned, it may shift easier if the TA is pulled back. In any event, at the least the TA needs to be adjusted or maybe rebuilt. If the "hard to shift" means the gears clash, that may also be a TA problem, or you may have too much pedal clearance in the main clutch, or both. The linkage can also be loose, with worn parts. The main clutch usually wears until you can no longer get the proper pedal clearance, in other words, it slips.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
