Posted by rustred on February 26, 2011 at 08:09:01 from (74.200.18.155):
In Reply to: idle speed WD-9 posted by plow hand on February 26, 2011 at 05:59:06:
there is no actual adjusting screws for the rpm. only on the wd40 you could open the butterfly with a screw and get more rpm. on this f8 carb i believe rpm is controlled by the air valve on top of carb.need 1/8" gap between carb body and valve. they only idle at about 400-500 rpm on gas, and as they warm up they will pick up some rpm. what rpm do you have. that is the secret to a long lasting deisel engine , run them slow till oil gets through the brgs. on the JD's there was a decompression lever you pull to register oil pressure then release it and fire it up on deisel.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
