Re: 1955 farmall 400 compression ect. ?
Posted by D Slater on February 26, 2011 at 16:12:28 from (184.15.45.226):
In Reply to: 1955 farmall 400 compression ect. ? posted by bugspot on February 26, 2011 at 15:35:52:
Engine has to idle down real slow to set the time at TDC with the engine running. If the engine is running at a steady speed when the timing is jumping around, I would go through the distributor and check all the advance mechanism parts for defects. Set the time at high idle on the 25 degree mark then if the engine will idle down slow and the advance parts work it should come back to near TDC.
