300 TA ???????
Posted by Farmall Dann on February 26, 2011 at 18:20:29 from (96.60.16.231):
My 300 I just bought was hanging in gears had to push and pull shifter real hard to get in to netural. Adjusted clutches to spec. went to haul manure every thing seemed fine.Spread the load started out of the bottoms made it 3/4 way up engine pulled down so I pulled back on TA it made a loud grinding noise and would not go in. released lever. It still makes grinding noise except when going down hill or setting still in netural. Any ideas? Thanks and have a good day!!!
