Rtkman.Heck of a lot of tension on the brush holder spring assembly. I would pull the starter apart and check the armature with a volt ohm meter to see if there is a section (or sections) that are Dead. Ground the volt ohm meter (ground clip it to the end of the steel shaft side.Rum the other VOM Hot around the armature ,watching to make sure there is NO CONTINUITY SHOWING ON THE GAUGE. if there is, good by armature assembly. Son is sending a service bulletin to help.Regards,LOU
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
