Re: Brgs. and seals Super A final Drive
Posted by CNKS on February 27, 2011 at 07:42:30 from (216.144.104.128):
In Reply to: Re: Brgs. and seals Super A final Drive posted by Tom Fleming on February 27, 2011 at 05:23:08:
Not surprising, whether intentional from IH, I don't know. An advantage for us is that bearings fit several different applications, otherwise I doubt if the companies would still be making them.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
