A 6v generator will not run wild. It can either not work, or if connected backwards the regulator can smoke. With a 12v battery and a 12v regulator on a 6v generator, it may actually work well enough to get by (not recommended, but not running wild) If it is a 12v gen (or converted 6v generator it will be fine. The voltage at the resistor should be battery voltage. The voltage at the coil to resistor should be about 7 to 9 with the points open. If the points are closed there should be no voltage at that wire. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
