Posted by Owen Aaland on February 27, 2011 at 15:37:58 from (65.174.247.39):
In Reply to: 12 volt conversion ??? posted by gene bender on February 26, 2011 at 12:57:14:
You may want to think about those voltages again. :?
With the points open the voltage in the entire circuit through the movable breaker point arm is going to be battery voltage. With the points closed you will see battery voltage before the resistor, reduced voltage between the resistor and coil, and no voltage between the coil and points.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
